Message error : the following translators
Thread begun 2/19/2012 2:02 pm by CreateCool | Last modified 3/06/2012 7:52 am by Jason Byrnes | 3161 views | 7 replies |
CreateCool
Hello ,
I ' m on XP 3 / DRW CS 5.5
I just upgrade data assiste from 2.0.8 to 2.1 and install Design Extender 1 and now when I Open dreamwever I have this message error / the following translators were not loaded due to error :
Pls can you help me to know how can I resolve it ? ( I have already deleted the .dat)
Thanks by advance
CreateCool
Following previous message
First part resolve by adding the file : in the Configuration\Shared\WebAssist\Documen tEncoding.js
DocumentEncoding.js and made this correction :
in the Configuration\Shared\WebAssist\Documen tEncoding.js file, change line 351:
Code:
if (theServerLanguage == "vbscript") {
Code:
var theServerLanguage = "PHP";
Stay the 2nd message error
The second error can be resolved by going to the following dreamweaver menu option:
Window->Workspace Layout->Reset 'your layout'
CreateCool
Well done, it's work
Thanks Ray
Roland Rogers
where is the file?
Where do I get the file to put there to be able to alter the code?
Neither the folder nor file exists on my system: WebAssist\DocumentEncoding.js
[ Vista, CS4 ]
Any help appreciated.
it in the users configuration folder.
see the common installation issues PDF for help locating the configuration folder:
from there, go to:
Configuration\Shared\WebAssist\DocumentEncoding.js
Roland Rogers
Thanks Jason, but what I meant was that I do not have a "WebAssist" folder in the "Shared" folder in which should be the "DocumentEncoding.js" file.
I have no trouble deleting the WinFileCache file and have done that a few times to remedy this issue. A previous poster wrote some code to put into the DocumentEncoding.js file but I do not seem to have it on my system.
I have been using WA extensions for years. I did just install the Design Extender after removing the other extensions that it replaces, if that helps with my diagnosis.
Is it a case of just getting that .js file and putting it where it needs to go? If so where can I get a copy of that file?
all the WebAssist extensions get installed to the shared/webassist folder, that folder would only not exist if no webassist extension are installed.
