cURL
Thread begun 2/19/2012 3:14 am by john378895 | Last modified 2/19/2012 4:40 am by gruant2000381341 | 1195 views | 1 replies |
john378895
cURL
when i try to install power cms on my testing server i get this message
cURL is not installed. Contact your hosting provider to have cURL installed.
gruant2000381341
This is how you enable curl if you are using xampp as your testing server
*note, different versions may have the php.ini file in a different location
1) Locate the following files:
C:\Program Files\xampp\php\php.ini
* other versions may also have multiple ini files here
C:\Program Files\xampp\apache\bin\php.ini
C:\Program Files\xampp\php\php4\php.ini
2) Uncomment the following line on your php.ini file by removing the semicolon.
( *around line 952 on my version)
;extension=php_curl.dll
3) Restart your apache server.
