UniversalEmail4
Thread begun 2/18/2012 2:40 am by elton | Last modified 2/22/2012 11:09 am by Jason Byrnes | 3930 views | 7 replies |
elton
UniversalEmail4
Hi Jason
Since I installed Design Extender I have had this repeatable problem when I attempt to use the database functionality of Universal Email 4.0.1:(
The require_once() at top of wa_appbuilder_php.php is being created with the wrong directory path for the file library.php. It fails to pick up the directory path at all.
If I turn off the database (error log tracking) functionality, there is no problem.
If I turn on error logging (to data base), and the error repeats each time the wa_appbuilder_php.php is generated.
Top of source for: wa_appbuilder_php.php
- This file contains proprietary and confidential information from WebAssist.com
- corporation. Any unauthorized reuse, reproduction, or modification without
- the prior written consent of WebAssist.com is strictly prohibited.
- Copyright 2005-2007 WebAssist.com Corporation. All rights reserved.
require_once("library.php");:confused:
IT SHOULD BE:
require_once("../framework/library.php");:)
// Application Builder functions
function WA_AB_getLoopedFieldName($tName, $loopInde) {
if (!strlen($tName)) {
return $tName;
if (strlen($tName) == 1 || substr($tName, strlen($tName)-1) != "_") {
$tName = $tName . "_";
return $tName . $loopInde;
Actually the most recent update of DataAssist shouldn't be including the library file at all. Have you updated DataAssist recently?
elton
UniversalEmail4
I'm using Data Assist 2.1.0. But why should that matter. I am calling a function from within Create EMail (Universal Email 4.0.1): Configure EMail Logging function. The problem only occurs when using Email logging to my MySQL database. If I deactivate the logging the problem does not happen.
Wouldn't this be caused by the code in UEmail.
elton
UniversalEmail4
Here are my "helper" files
elton
Originally Said By: elton
I found I could get the file to load by doubling the horizontal and vertical MAXSIZE parms in the kfm files from 1024 x 768
to 2048 x 1700. However, after loading the file, it still does not show. I get a blue circle with a diagonal bar through it instead of the image. The image is on the server, but not displaying...just the blank box and symbol.
I stripped down my website to bare walls...and reinstalled from scratch with Design Extender. The problems went away. It seems that there are some risks to using the extensions on an existing site, but it works as expected on a new build.
elton
I wiped my site and recreated using Design Extender and the imaging problems went away.
ok, glad to hear it is working.
