hidden field not populating column
Thread begun 2/17/2012 11:49 am by asarcona308398 | Last modified 2/17/2012 5:00 pm by asarcona308398 | 3550 views | 7 replies |
asarcona308398
i am using DA with a repeat selection from a recordset and the hidden field that DA creates: <input type="hidden" name="took_attendance_mihidden_<?php echo $RepeatSelectionCounter_2; ?>" id="took_attendance_mihidden_<?php echo $RepeatSelectionCounter_2; ?>" value="A" /> ---> it's value "P" is not being passed into the database column if the checkbox that it represents is not "checked".
the default value that DA associated with the hidden form was "1" and I changed it to "A" as it is an attendance form and who is present should be recorded as "P" and who is absent should be "A"
any help would be much appreciated
thanks,
tony
After looking into the database further I've discovered a greater problem..
The inserted rows is the first returned rowset from the query, repeated over and over.
I thought the query was at fault but ran it through Devart's Query Builder and it returned correct results...
I hope this is something that has been seen before
I've included an updated version of the file, attendance_2.zip is latest
thanks again,
tony
the value of the checkbox will only be sent if the checbox is checked, this is the way a checkbox works, if it is not checked, no value is sent.
the checkbox is also used by the insert record behavior as a trigger for inserting that record, if not checked, no record for that column is created. I would recommend using a radio group instead of a checkbox.
the other issue is because you are using recordset data in the insert behavior, the recordsets are configured to filter using query string variables. When the page first loads, the querystring variables are passed in, but the forms action does not pass them when it sends the form data, so the recordsets are not filtering correctly on post.
change the form tag:
<form  action="" method="POST" name="attend_date">
<form  action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlspecialchars($_SERVER["QUERY_STRING"]):""?>" method="POST" name="attend_date">
this will include any existing querystring variables when the form is posted.
asarcona308398
form is set to "post"....
checkboxes will be either marked or not, if not marked the hidden form value is supposed to stay in effect, as I understand a checked checkbox that "Post" should override the hidden input form field value.
Also --- the form gets into the database, the issue of the previous hidden form values that are skipped over is the problem, the record is entered, but the column is not populated for the hidden form field value,
and lastly... the first record values are repeated in the database for as many rows are inputed
thanks,
tony
asarcona308398
I'm not sure a radio is possible as many entries are required...
I'll add the querystring variables and hope that solves the repeating data rows problem, thanks so much for looking at this
thanks,
tony
asarcona308398
hey Jason,
very frustrating....
changed the action attribute, and the inserts were the same, repeated the first value and the hidden form field attribute did not post to database column...
the checkbox does not override the hidden element. Either the checkbox is checked and has a value or it is blank and does not have a value.
this is why i suggested using a radio group, this way you have one radio button for "A" and another radio button for "P"
the insert will not loop through the recordset data.
you need a form field for each recordset column set the form field to use the recodset info, and bind the insert to the corresponding form element instead of binding to the rs column.
asarcona308398
Jason,
added the visible form fields as well as the variables to the form action, and all is well, thanks a million...
I'm just wondering why hidden form fields will not work instead of having to show back end data to users... when I use hidden form fields bound to the recordset I get NULL entries in the database columns for those form fields and all the rest are populated correctly??
thanks,
tony
asarcona308398
found the problem with the hidden fields.. selecting them from the form fields in the dynamic lightning bolt dialog box does not permit them to work as the don't seem to be inserted in the behavior as a "repeating" field as it labels itself after being chosen... choosing the hidden fields from the drop down box lists them as repeating fields and the insert multiple record behavior works.
I hope you guys document this as it can be re-created at will and is very difficult to find.
thanks for the great support and attention,
tony
