Misdirecting After Update
Thread began 2/17/2012 6:57 am by salaroche | Last modified 2/17/2012 7:54 am by salaroche | 1286 views | 2 replies |
salaroche
Jason:
I created a search sequence in a Website using DA's Search Wizard and then I duplicated the pages and changed the names of the duplicate pages. Now I have two Search sequences in the same Website (It's the same Website whose other problem you solved yesterday)
The first sequence is working well, but the second sequence's AUpdate page is misdirecting to the DDetails page of the first sequence. All the other links and pages of the second sequence are working fine.
I've tried changing the page name in the "After Update - Go To (optional)" field in the Update Record Wizard, but DA completely disregards any changes I make there. Even if I leave that field blank it still redirects to the same wrong page after Updating.
Is there any hidden code redirecting to the "original" page?
You can check out the problem by clicking on the following link:
index.php
The passwords are the same I gave you yesterday.
Any sugestions?
Attached please find a copy of the AUpdate page.
Thank you for your attention
AUpdatePage.zip
the forms action is set to post to the DUpdate.php page, not the AUpdate page:
<form action="DUpdate.php?ID=<?php echo(rawurlencode($row_WADAclassrecords['ID'])); ?>" method="post" name="WADAUpdateForm" id="WADAUpdateForm">
when the form posts, the info entered on the AUpdate.php page is sent to the DUpdate.php page for processing....
change the action to post to the correct page.
salaroche
Jason:
Done.
Many thanks.
