Validation ShowIf Shows after correction
Thread begun 2/16/2012 11:20 am by sandy259886 | Last modified 2/16/2012 2:01 pm by Jason Byrnes | 2890 views | 5 replies |
sandy259886
I added a validation show if error message to a form submission. It shows up when the captcha code does not match ... That is good. It never goes away after that when I go to a different product page. Looks like the variable isn't getting reset.
You can test it at my testing site: detail.php?PKey=1193
How do I fix it?
the validation failure is stored in a session variable. the session variable is cleared once the form submits successfully.
you need to successfully submit the form to clear the validation error messages.
Or you could add code to clear the session at the bottom of the page, send a copy of your page and I can tell you what code to add.
sandy259886
here it is!
Here is the page
add the following code after the </html> tag:
<?php if(isset($_SESSION['WAVT_detail_768_Errors'])) unset($_SESSION['WAVT_detail_768_Errors']); ?>
sandy259886
Works like a charm :) Thanks loads.
you're welcome.
