Form validation
Thread begun 2/16/2012 9:35 am by bill3786 | Last modified 2/28/2012 11:12 am by Jason Byrnes | 5303 views | 11 replies |
bill3786
Form validation
The site backend has a number of forms for inserting and updating various database columns where the values can only be 0 or 1 and another can only be 1,2,3 or 4
These particular fields have a column type of tinyint(1)
I would like to apply validation to the field as it being entered, in the same way that the validation of the fields work in the registration page.
For example if you try to enter an email address in the email field which is not an email format and then move to the next field a mesage is instantly displayed and the field displays a red background.
Can this be done in the same way for a numeric field to check for an entry of only 0 or 1 and for only 1,2,3 or 4
you will need to use Spry validation for this, Insert -> Spry -> Spry validation text field.
set it to validate on blur. set the validation type to integer, and set the minimum and maximum values to limit the numbers that will be accepted.
sybil_thewriter317416
Insert New Form Errors
Error generating: buildFieldGroup TypeError: ShowIfObj.setParams is not a function
followed by
Error generating: buildColumn, buildFieldGroup, buildColumn, buildFieldGroup,(goes back and forth between these two messsage)
Then a form displays missing the Name, Email and Captcha
Jason, I tried to start a new thread but the Image Verification box was empty.
Help. :-)
What version of form builder.
This sounds like an error from a previous form builder release that is corrected in the CSS Form Builder 2.0.1 support release 2 version that is available in the support release section of the Form Builder 2 download center page.
you will need to uninstall the current version before installing the newer one.
any onshnv
I just bought it yesterday. version 2.0.0
Found It
Hi Jason, I went back to my downloads and scrolled down and found the update you referred to. I'm just extracting it now. Hopefully no more problems.
bill3786
Follow on from post no. 2
Added spry validation to all the backend datassist generated insert and update pages.
Only had a problem with the password field on the user update page. Tried to change the spry validation from a required text field to a password type validation using the same parameters as the password field on the registration page.
This would accept a valid password but would blank the password field on submit in the database.
It works ok when I reverted back to a required text validation field but obviously doesnt check for a valid password.
i would need to see the code in your page to troubleshoot.
bill3786
The users_update page has been changed back to text spry validation on the password field and will perform an update to this field ok but obviously does not check for a valid password which is what I want it to achieve when this problem is cleared.
Also after adding spry password validation to the password field on the users insert page this also causes a blank entry for password in the database.
Also my registration page is not passing the phone number into the database. Not done anything to this page recently other than some time ago added company name and two extra address fields. After looking at the code is there a problem with the tab index value?
Attached are the users_update, users_insert and registration pages.
for the users update page, i need to see the code that doesn't work after you have changed it.
for the insert page, the Insert Record behavior is expecting the password form element to be named "UserPassword", you have named it "password" when changing the form element type, it's important to copy the name of the original form element, and re use that name for the new spry element that you replace it with.
change the password text field:
<input type="password" name="password" id="password" size="32" />
<input type="password" name="UserPassword" id="UserPassword" value="" size="32" />
similar problem with the phone field on the registration page, the insert behavior is expecting the phone field to be named "Registration_group_1_Phone", but the form element on the page is named "Registration_group_Phone".
on the server behaviors panel, double click the Insert Record behavior, on the second step of the insert behavior, select the Phone number column of your users table, then click the lightning bolt, in the data bindings, select the Registration_group_Phone form element.
