Session Variables
Thread begun 2/15/2012 11:48 pm by salaroche | Last modified 2/16/2012 9:55 am by Jason Byrnes | 3891 views | 7 replies |
salaroche
Session Variables
Hi:
The MM_Username variable is working well across my Search, Results, etc. pages, but I would need to create another Session Variable to pass some User-entered info around. How do I do that? I've been Googling this for hours, but I haven't found the appropriate answer.
The idea would be to pass the teacher name selected by the user in the Search Page to the rest of the pages. I've tried a few things, but I always get the error message "undefined variable". Any suggestions?
Attached please find a Search and an Update pages.
Thank you for your attention
add the following code to the results page at line 1 to set a session variable for each form element from the search page:
@session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $k => $v) {
// store as session
$_SESSION[$k] = $v;
the teacher element is named S_teacherName, you can use the following code on the update page to reference the session that is created:
<?php @session_start(); echo((isset($_SESSION["S_teacherName"]))?$_SESSION["S_teacherName"]:"") ?>
salaroche
Jason:
Thank you for your reply.
I suppose $v stands for the name of the form element (i.e., S_teacherName) What does $K stand for? A Session Variable name I should come up with?
$k stands for the key, or element, name. $v stands for the value.
so this line:
$_SESSION[$k] = $v;
creates a session that has the name of the form elements, and sets the value of the session to the value of the form element.
so your S_teacherName form element gets stored in a session named S_teacherName with the value that was posted.
salaroche
Jason:
I Replaced both $k with S_teacherName and I created a new Session variable called S_teacherName (is that correct?) But when trying to show the content of S_teacherName I get the following error message:
Notice: Undefined index: S_teacherName in C:\xampp\htdocs\DjibOx.com\AUpdate.php on line 266
Any suggestions?
you dont need to replace anything in the code i sent you.
use this code unchanged on the results page:
@session_start();
if(
    foreach(
// store as session
$_SESSION[$k] = $v;
and this code unchanged:
to display the S_teacherName session variable value
salaroche
Jason:
I entered the code unchaged in the corresponding pages, but it doesn't display anything on the AUpdate page. What I am not doing right?
