Problem
Thread begun 2/15/2012 8:59 pm by Fobbert | Last modified 2/17/2012 1:52 pm by Jason Byrnes | 3908 views | 7 replies |
Fobbert
Problem
After thousands of hours I can still not get this to create a PHP Site
New Site Sculpture Site out of Design Extender.
Using Dreamweaver CS5.5, Create a raw PHP file with a connection to a mysql database and table even. The default page type for the site is PHP and the site of cause is PHP-MYSql.
There are several problems all round like creating and defining all your own layout dose not always save, but the part that pssssss me off the most, it generated pages are all HTML. I use to use the old system (Super Suite) with more luck at least you could create a PHP site.
Have gone back to doing it all manually.
Any Ideas
MikeH
Hi
I have also experienced the refusal to save changes at times.
It looks like they are there and then you save and find it actually ignored them.
(Design suite css sculptor)
Mike
Mike, can you provide steps to reproduce the problem?
MikeH
Hi Jason (right name)
Just create a basic design using a preset ie 2 column fixed width.
When I try to change the text colour for headings all looks ok but the page it creates does not have those changes and when you open Sculptor up again they are back to default.
Thats all I did. Its easily got around by a manual edit so its not too annoying but would be good if it worked.
Im having to make a change save then go back in make another change just in case they do not save.
Mike
Hmmm, I'm not able to reproduce this.
MikeH
Jason
After we spoke, I made a few more changes to the layout and those changes you saw me make defaulted again. So I changed them again all fine. I went back in made a few changes elsewhere and they defaulted back. It seems to be mainly an issue with changing of the TYPE section. They keep defaulting.
Mike
interesting, i have reopened the ticket i created and will look into this with you next week.
