Forgot Password page issue
Thread begun 2/15/2012 12:39 pm by Steve | Last modified 2/16/2012 1:07 pm by Jason Byrnes | 4097 views | 8 replies |
Steve
Hello,
Basic wizard created password retrieval page is giving an error
" Unknown column 'UserEmail' in 'field list "
if(isset($_POST["ForgotPassword_submit"])){
//WA SecurityAssist Email object="mail"
$WA_Auth_Parameter = array(
"connection" => $MySQLcmhi,
"database" => $database_MySQLcmhi,
"tableName" => "tblretailer",
"filterColumn" => "retailerid",
"filterEncryption" => "",
"columnValue" => "".((isset($_POST["Forgot_Password_group_Email"]))?$_POST["Forgot_Password_group_Email"]:"") ."",
"columnType" => "int",
"usernameColumn" => "retaileremail",
"usernameEncryption" => "",
"passwordColumn" => "UserPassword",
"passwordEncryption" => "",
"selectColumns" => array("UserEmail","UserPassword","retaileremail","retailerid"),
"sessionVariables" => array(""),
"successRedirect" => "access.php?emailedPassword=1",
"failRedirect" => "forgotpassword.php?notFound=1",
"keepQueryString" => TRUE,
"toAddressColumn" => "retailerid",
"toAddressEncryption" => "",
"fromAddress" => "Administration@domain.org",
"fromAddressDisplay" => "Administration",
"subject" => "Forgotten Password",
"mailBody" => "webassist/security_assist/email/forgotpassword_email2.php",
"emailFunction" => "WA_SecurityAssist_Email_1_SendMail"
WA_Auth_ForgotPassword($WA_Auth_Parameter);
In the SecurityAssist: Email Password panel under DataBase tab the Lookup Value is:
<?php echo ((isset($_POST["Forgot_Password_group_Email"]))?$_POST["Forgot_Password_group_Email"]:""); ?>
I'm thinking of creating a recordset based on the user email address and then using that as the lookup value but would like to better understand the extensions requirements before I deviate to hand coding.
the error is saying that in the tblretailer table, there is not a column named UserEmail
What version of security assist?
Are you testing locally or remotely?
what is the structure of the tblretailer table?
Steve
Hello Jason,
Latest Version of Security Assist
Testing to live server
Table structure as follows:
CREATE TABLE IF NOT EXISTS `tblretailer` (
`retailerid` int(11) NOT NULL AUTO_INCREMENT,
`retailername` varchar(75) DEFAULT NULL,
`retaileraddress` varchar(50) DEFAULT NULL,
`retaileraddress2` varchar(50) DEFAULT NULL,
`retailercity` varchar(25) DEFAULT NULL,
`retailerphone` varchar(15) DEFAULT NULL,
`retailerfax` varchar(15) DEFAULT NULL,
`retailerstate` int(11) DEFAULT NULL,
`retailerzip` varchar(15) DEFAULT NULL,
`retaileremail` varchar(50) DEFAULT NULL,
`retailerwebpage` varchar(70) DEFAULT NULL,
`retailerregionid` int(11) DEFAULT NULL,
`subretailerregionid` varchar(70) DEFAULT NULL,
`retorcomm` int(11) DEFAULT '0',
`retailertype` tinyint(4) DEFAULT '1',
`cnt_name1` varchar(75) DEFAULT NULL,
`cnt_email1` varchar(50) DEFAULT NULL,
`cnt_phone1` varchar(15) DEFAULT NULL,
`cnt_name2` varchar(75) DEFAULT NULL,
`cnt_email2` varchar(50) DEFAULT NULL,
`cnt_phone2` varchar(15) DEFAULT NULL,
`memb_Info` text,
`pdfpath` varchar(60) DEFAULT NULL,
`tollfree_no` varchar(30) DEFAULT NULL,
`keyword` varchar(255) DEFAULT NULL,
`estar` smallint(2) DEFAULT '0',
`lat` float(10,6) DEFAULT NULL COMMENT 'added 2/2012',
`lng` float(10,6) DEFAULT NULL COMMENT 'added 2/2012',
`UserPassword` varchar(500) DEFAULT NULL COMMENT 'password',
PRIMARY KEY (`retailerid`)
I dont see a UserEmail table in that structure
Steve
Yes that is correct. The email table is `retaileremail`
this line:
is referencing the UserEmail column
change it to:
"selectColumns" => array("UserPassword","retaileremail","retailerid"),
Steve
Hello,
Now it can't find the email address
"Your email address could not be found in our records. Please try again."
Linked somehow to the prior value we just moved? Also where is the area to retarget the 'UserEmail' value? It was originally set in the Wizard that used the powerCMS2v default.
UPDATE
I saw two references to retailerid which I changed to retaileremail and now it notes that the send was successfull
"filterColumn" => "retaileremail",
"toAddressColumn" => "retaileremail",
"filterColumn" and "toAddressColumn" both were targetting the retailerid value... Not sure where these got crossed up
Steve
Emails received but in the email there seems to be that global that I can not track down.
Rather than show the actual email address in the received email it references the UserEmail:
Username: [UserEmail]
Password: xxxxxx
send a copy of the webassist/security_assist/email/forgotpassword_email2.php page so i can see the code that creates the email
