Upload Not working
Thread begun 2/13/2012 12:33 pm by BeDigital94844 | Last modified 2/14/2012 11:02 am by Jason Byrnes | 1898 views | 3 replies |
BeDigital94844Beta Tester
Upload Not working
Hi-
I have used DA 2.08 and have had this working in the past -
but now with DA 2.10 I seem to have an issue- the insert to database is working perfectly but the file is not getting to the directory on the server-
I checked permissions 775
muli-part form OK
is there a setting on the server- I missed?
safe mode off
It ALL works perfectly at the root of the file system- but if I create it, or move it to a sub-directory e.g. /CMS/
it will fail - I checked the relative paths settings; site vs document - it is set to "document"
any help would be very much appreciated-
----code as follows-----
<?php require_once('Connections/espn_techcenter.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("webassist/file_manipulation/helperphp.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "images/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "logo_sponsor", "0", "", "true", $WA_UploadResult1_Params);
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $espn_techcenter;
$WA_table = "sponsors";
$WA_sessionName = "WADA_Insert_sponsors";
$WA_redirectURL = "Detail.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "id_sponsor";
$WA_fieldNamesStr = "name_sponsor|logo_sponsor|date_sponsor";
$WA_fieldValuesStr = "".((isset($_POST["name_sponsor"]))?$_POST["name_sponsor"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".((isset($_POST["date_sponsor"]))?$_POST["date_sponsor"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,NULL";
$WA_connectionDB = $database_espn_techcenter;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Insert sponsors</title>
<link href="WA_DataAssist/styles/Traditional_Moab.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAInsertContainer">
<form action="Insert.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">Sponsor ID:</th>
<td class="WADADataTableCell"></td>
</tr>
<tr>
<th class="WADADataTableHeader">Sponsor Name:</th>
<td class="WADADataTableCell"><input type="text" name="name_sponsor" id="name_sponsor" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Sponsor Logo:</th>
<td class="WADADataTableCell"><label>
<input type="file" name="logo_sponsor" id="logo_sponsor" />
</label></td>
</tr>
<tr>
<th class="WADADataTableHeader">Date:</th>
<td class="WADADataTableCell"><input type="hidden" name="date_sponsor" id="date_sponsor" value="" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="WA_DataAssist/images/Moab/Traditional_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="sponsors_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Moab/Traditional_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</body>
</html>
to help troubleshoot the issue, remove the redirect from the insert behavior, change:
$WA_redirectURL = "";
add this code at line 1:
error_reporting
(E_ALL);
then just before the closing </body> tag add the following code:
echo("<pre>");
var_dump($_FILES);
echo(
"</pre>");
echo
WA_DFP_AllUploadsDebug();
this will write some debug info to the bottom of the page, please post this information back
error_reporting
(E_ALL);
echo("<pre>");
var_dump($_FILES);
echo(
"</pre>");
echo
Jason-
many thanks - I did manage to get just about everything working-
there is one "custom" bit that I would like some help with-
I am able to add a "new" sponsor, with name, logo and update and delete it
what I would also like when adding/insert new sponsor a file directory is created or copied and renamed - I would not mind taking a 1-1 session to sort this out at your convenience
we offer assistance with custom coding through our premiere ticket appointment, see the support landing for details on signing up for a premiere support ticket.
