Dataassit with Godaddy server
Thread begun 7/22/2009 9:51 am by eleni321787 | Last modified 7/22/2009 11:21 am by Ray Borduin | 4551 views | 5 replies |
eleni321787
Hi, I am trying to use the Dataassist that I just purchase for the website we are hosting with Godaddy. The form is a SQL registration form. I have ODBC connection to the database as per the provided script by the godaddy. What I am trying to use the Dataassit is to create Insert, Update and delete form with ASP.
I used the Dataassist wizard and follows the step to create these forms. Now, when I tried to test the insert form, I am getting "internal server error". I am not sure whether this product is working with Godaddy or not. I know they don't allow some files in a shared hosting and I am not sure about this. If it works with their server, Whatelse I need to do?
Thanks,
Eleni
What is the url where you are getting the error? It may be a problem with your database connection information.
eleni321787
Dataassist with Godaddy
Registration_Insert.asp - this is the insert form page and when I hit the insert button the same URL comes with the Internal server error.
I create a recordset and test the connection and I able to see the table. I don't think it is a connection issue.
Can you create a blank page. Add a DW recordset, and view data from the database? If you can't then it is a connection problem.
eleni321787
Like you said, I just created a new page and recordset and managed to see the table. The connection is working. The issue I have is with Dataassist.
You saw the table data on a live page on the same server? Do you have a sample url? The next thing to do would be to debug the precise line of code causing the error. Most likely the line of code that does the insert. Then write the insert code to the page so you can see what it is trying to do and might be able to spot the problem.
