Install not working
Thread begun 2/09/2012 10:59 am by brendafos379366 | Last modified 2/21/2012 7:41 pm by brendafos379366 | 4448 views | 10 replies |
brendafos379366
Install not working
I've got a couple of other websites already using PowerCMS, so you'd think I could get this working.
I've uploaded the file, and created the mySQL db, BUT when I run install using the path index.php -
The first time I did this the wizard started and said I needed to change the permissions on the folder - which I did, then I click try again and it goes to a blank page /install_cms/serial.php. NO errors to work with.
So I delete the folder, re-upload everything and try again (fixing the permissions on the powercms folder first to 755). Nothing just goes immediately to /install_cms/serial.php
What do you suggest?
when a php page displays blank, it means a php error is occurring.
add the following code to line 1 of the install_cms/serial.php page to turn error reporting on:
error_reporting
(E_ALL);
once we know the error we can have a better idea of what is causing it.
brendafos379366
results
Here's the error message I got:
Fatal error: Maximum execution time of 30 seconds exceeded in C:\CustomerData\webspaces\webspace_00273968\wwwroot\webedit\webassist\framework\library.php on line 9
try adding the following code to the webassist\framework\library.php file at line 1:
<?php set_time_limit(); ?>
brendafos379366
OK, did that.
Started again at powercms/index.php
The wizard came up, got past the system check page,
I clicked continue
then
I got this page - powercms/install_cms/database.php
and got this error -
Reply With Quote
The first four lines of /library.php -
[php<?php set_time_limit(); ?>
if (!isset($absolutepath)) {
Did I do it wrong?
I am hosting with a new host - Dotser.com, wonder if they are the problem?
sorry, i was missing a ] square bracket in my previous reply.
the first 3 lines of the file should be:
brendafos379366
and nw
OK, made the correction and ran it again -
Now get this error from page - install_cms/serial.php
Warning: Wrong parameter count for set_time_limit() in C:\CustomerData\webspaces\webspace_00273968\wwwroot\webedit\webassist\framework\library.php on line 1
Fatal error: Maximum execution time of 30 seconds exceeded in C:\CustomerData\webspaces\webspace_00273968\wwwroot\webedit\webassist\framework\library.php on line 13
sorry, try changing:
<?php set_time_limit(0); ?>
brendafos379366
just spins
Added the '0' parameter and ran install again.
I gets to this page - diagnostic.php, I hit enter and it just 'spins' and never progresses to the next stage. So it has yet to ask me for the database information.
Now what? Do you think I should move my hosting to Hostgator where I have many other accounts which are not having this problem? Or what?
