Prevent product 2 being added if product 1 is not in the cart
Thread begun 2/09/2012 8:00 am by doug8382 | Last modified 2/10/2012 6:51 am by Jason Byrnes | 4588 views | 10 replies |
doug8382
ok, i have 3 variations of one product set to replace (ID 1) if it is added by another variation.
That works great. Now, there is a second product with 2 variations (ID 2) that should only be able add if the product ID 1 is in the cart.
I think I read you could wrap the cart with if statement. I'm using ASP VB Script and E Cart 3.
Could you help me display at the very least, an error message saying you must add Product 1 before adding product 2?
Or any other solution you think would be best.
Thanks,
Doug
doug8382
a little help please
Hey Jason, do you think I could get a little help on this one. time sensitive would appreciate some advice.
thanks,
Doug
You would have to write an if statement on the add to cart page, but would probably have to update the view cart page too in order to prevent them from removing the required item afterward.
This is a bit beyond what we handle on the public forum, but we can help you with the support incident you have purchased.
doug8382
Hey Ray,
Thanks so much for getting back. I can point to a lot of threads where Jason and others are extremely helpful and often writes snippets of code.
I would just like some direction on what variable to target and how it might be written. I see this kind of help from Moderators all the time.
Sorry if I came across as impatient, but I am on deadline, and was excited at first to see the thorough and prompt replies, only to be told this is not covered in forums, when it clearly is.
appreciate any guidance on my issue, which I thinks, should be a simple one.
Thanks,
Doug
doug,
it's easy enough to hide the add to cart button unless Item ID 1 is in the cart, that code would look like:
<% If WA_eCart_InCart(eCart1, "1") Then %>
<add to cart button form for product 2>
<% End If %>
this code example assumes the cart is named eCart1.
the part Ray is saying is not supported and beyond what we can do in the forums is editing the cart display page so that if item 1 and item 2 are in the cart, you cannot remove item 1
doug8382
almost
Hey Jason,
Thanks for the snippet. It seems whenever i surround anything within an ecart form with that code i get this error.
Microsoft VBScript runtime error '800a01a8'
Object required: 'cartObj'
/WA_eCart/WA_eCart_Definition_VB.asp, line 81
Any idea why that's happening?
Thanks,
Doug
I'd need to see the code, send a copy of your page in a zip archive please.
doug8382
thanks
Thanks Jason,
I've attached all the files in the app. Your code is on the workshops.asp file. I think I'd prefer to hide the cart display page and display an else if message like "You must add Product 1 to the cart before adding product 2". But hiding the add cart area would work as well.
Thanks,
Doug
hiding the cart display page does not make any sense, they would not be able to see any items in the cart until item 1 where added....
any way, the error message is caused by using a different cart name. the code example i gave assumes the cart is named eCart1, your cart name is WA_eCart1. Slight difference, but it's enough to through off the asp processor.
you need to alter the code to use the correct cart name:
<% If WA_eCart_InCart(WA_eCart1, "1") Then %>
<% End If %>
doug8382
thanks
thanks again Jason. I missed the cart name and that works. Really appreciate the help.
you know i've had this cart for a few years and haven't really used it. I like it but need to get up to speed on discounts, so you may see me again. I have an upcoming project that ver 5 might work. I'll need product specific discounts.
I've read through the docs on discounts and calculations. a little confusing at first. are there any other resources for targeting that subject? again, thank you.
Thanks,
Doug
