mkdir() Issue with Form Upload
Thread began 2/08/2012 10:36 pm by jyotimarshall435194 | Last modified 2/10/2012 9:16 am by Jason Byrnes | 2070 views | 6 replies |
jyotimarshall435194
Hello!
I am having a hard time figuring out what is wrong with the form I just created using Form Builder. I built a simple form with file upload and added to a blank PHP page. Filled everything out (like when it asks where to save files) but when I test it online, get a list of errors:
Warning: mkdir() [function.mkdir]: Invalid argument in D:\Hosting\2431357\html\bsq\webassist\file_manipulation\helperphp.php on line 30
Warning: mkdir() [function.mkdir]: Invalid argument in D:\Hosting\2431357\html\webassist\file_manipulation\helperphp.php on line 30
Warning: mkdir() [function.mkdir]: No such file or directory in D:\Hosting\2431357\html\webassist\file_manipulation\helperphp.php on line 30
Warning: move_uploaded_file(D:\Hosting\2431357\html\b) [function.move-uploaded-file]: failed to open stream: Invalid argument in D:\Hosting\2431357\html\webassist\file_manipulation\helperphp.php on line 96
Warning: copy(D:\Hosting\2431357\html\53a2f69c8109264a5928f919260d706c_tmp.JPG) [function.copy]: failed to open stream: Invalid argument in D:\Hosting\2431357\html\webassist\file_manipulation\helperphp.php on line 98
Warning: require(Blank_3.php) [function.require]: failed to open stream: No such file or directory in D:\Hosting\2431357\html\webassist\email\mailformatting_php.php on line 142
Fatal error: require() [function.require]: Failed opening required 'Blank_3.php' (include_path='.;C:\php5\pear') in D:\Hosting\2431357\html\webassist\email\mailformatting_php.php on line 142
I can't seem to figure out what is wrong.
Thanks ahead of time.
send a copy of your page please in a zip archive so I can inspect the code.
jyotimarshall435194
Files
The index.php is the main file but I attatched the file_manipulation folder as well since it appears that there is something wrong with the helperphp.php file.
zipfile.zip
the problem is the upload folder setting.
at line 28:
'UploadFolder' => "file:///C|/Users/Yohan/Documents/Websites/Testing/",
this should not use a file system path, it should be a document relative path:
'UploadFolder' => "Testing/",
jyotimarshall435194
Ok thanks i will try that...the funny thing is that I used the Form Builder extension to select a folder...
jyotimarshall435194
Error
Thanks so much! That worked.
However, I have run into another problem now...In the upload options menu when I try to check the box for "Web images only," an error message pops up. Maybe I need to reinstall extension? I am not sure.
