Why I can´t see the map? I don´t show the map
Thread begun 2/07/2012 5:46 pm by gfabiano422639 | Last modified 2/08/2012 4:26 pm by gfabiano422639 | 2613 views | 5 replies |
gfabiano422639
I use DW CS5 with dynamic data in PHP. I don´t see anything.
can you send a link to the page please?
does the page show blank in the browser? if so, that would indicate a php error is occurring. add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
this will help us trouble shoot the cause of the problem.
gfabiano422639
Thanks for your answer, but I don´t have any error message
Just I don´t see anyseen. It´s possible the key of Google Maps be not valid because I need to confirm the new policy imposed by Google?
Thank you again.
gfabiano422639
Garrison, nismmi
Sorry, to see the problem there is the link ir2.php
Thank you again.
your page is missing the following code that should be just before the closing the </body> tag:
<script type="text/javascript" src="google_javascript/wagmp_maps.js">/*wagmp*/</script>
gfabiano422639
It´s works
Thank you very much. Now is working fine.
