Conditions help....
Thread begun 2/07/2012 9:45 am by arturo.civit | Last modified 2/23/2012 9:17 am by Jason Byrnes | 3345 views | 8 replies |
arturo.civit
Conditions help....
Hi there!
One question, how can I filter something coming from a database in PHP using a conditional, for example, I have a table with posted jobs, those jobs belongs to departments, for example
Brokerage - System
Brokerage - Management
Brokerage - Services
Brokerages - Payroll
Carrier - Real Estate
Carrier - Documents
Carrier - Programming
etc.
If you see, the departments are just 2 Brokerage and Carrier but in the database they are called like I described you Brokerage - Something and Carrier - Something.
I want to have 2 HTML tables, the table in the left with only posting the Brokerage Positions and the one in the right with the Carrier Positions, I used this on the left one:
if (@$row_rsBJ['Job_Department'] != "Brokerage") {
<?php do { ?>
<table>
</table>
<?php } while ($row_rsBJ = mysql_fetch_assoc($rsBJ)); ?>
<?php }
but didn't work, I need to filter with something like "Send me only departments that start with brokerage" or something like that, but my programming expertise is minimal, any idea? or suggestion?
Thanks so much in advance!
Arturo
assuming the name of the table is "jobs" and the name of the column is "departments"
you could use the following SQL for Brokerage:
SELECT * FROM jobs WHERE departments LIKE 'Brokerage%'
and this for Carrier:
SELECT * FROM jobs WHERE departments LIKE 'Carrier%'
arturo.civit
Hi Jason, thanks so much!! you're right, that should do the trick, the thing is, my query is a little bit complex, for example, the one that should call the brokerage ones is:
SELECT CompanyInfo.CompanyInfo_Logo, CompanyInfo.CompanyInfo_COName, Jobs.Job_Date, Jobs.Job_Position, Jobs.Job_Salary, Jobs.Job_Department, Jobs.Job_Division, Jobs.Job_City, Jobs.Job_State, Jobs.Job_Contact, Jobs.Job_Email, Jobs.Job_Summary
FROM (Jobs
LEFT JOIN CompanyInfo ON CompanyInfo.ID_User=Jobs.ID_User)
ORDER BY Jobs.Job_Date DESC
So now not sure where t place what you explained.
Thanks Jason!
A.-
FROM (Jobs
arturo.civit
FROM (Jobs
Hi Jason thanks a lot, now it works, thanks so much!
arturo.civit
FROM (Jobs
Hi Jason, again, thanks for all the help, I have one question, see, I need now to filter the departments and only print jobs under brokerage and certain departments, for example,
Show only brokerage jobs with Brokerage - System
or
Show only brokerage jobs with Brokerage - Administration
etc, how should I construct the query to have jobs listed only within the requested department? I plan to have 2 pages, one with the department categories where you can click on any and that should be sent as URL parameter like:
list-brokerage-by-category.php?<?php echo $row_rsShowCats['Job_Department']; ?>=Department Here
but the other page, the one that receives that parameter is where I need to construct that query.
Any idea will be greatly appreciated! Thanks!
A.-
you have the idea of the link backwards
list-brokerage-by-category.php?Department=<?php echo $row_rsShowCats['Job_Department']; ?>
this creates a querystring variable named Department that is given the value of the department name from the recordset.
for the recordset, set the where clause to:
WHERE departments = paramDepartment
then create a new variables as:
Type: Text
Default Value: -1
Run Time Value: $_GET['Department']
arturo.civit
Type: Text
Default Value: -1
As usual, thanks so much Jason!
you're welcome.
