current state not working
Thread begun 2/07/2012 8:13 am by sandy170299 | Last modified 2/08/2012 8:01 am by sandy170299 | 2605 views | 4 replies |
sandy170299
On this site, I have a current state defined, and the navigation is working correctly, but the current state CSS isn't showing up on the site when the pages load. It's not even working on the home page. Thanks!
index.cfm
in the menu try changing:
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }, true); }</script>
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 3, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 3, orientation: 1}); }, true); }</script>
sandy170299
Now they all appear in the "current" state.
See what I mean? index.cfm
It looks like it is working correctly when i visit your page, did you get this working?
sandy170299
Jason, I had to use a different menu system because I had to get it working yesterday. I couldn't use CSS Menu Writer :( I've had trouble with current states with CSS Menu Writer before, and I never figured out how to fix it. Hopefully, the next release will address this!!! Thank you for your help.
