Formatting Tags Showing
Thread begun 2/06/2012 9:12 am by jgroh96793 | Last modified 4/03/2012 4:08 pm by Jason Byrnes | 1942 views | 3 replies |
jgroh96793
When I added a html editor to my form and used it to input in some text, on the page that shows that text, it is showing the source formatting. So for example, I type into the html editor:
test
test
It will show up on the page as:
<p>test</p>
<p>test</p>
Is there anyway to fix this?
John
there is formating on the initial value of the HTML editor instance that is converting the double quote character (") to the html entity.
to fix the problem, edit the html editor instance, and re bind the initial value to the corresponding recordset column to remove the formatting.
nickj
As you can see in the images attached the initial value is correct but the formatting is still showing.
Am I supposed to add a css file elsewhere on the site?
Nick
