CSS Button Styler - browser compatibility???
Thread begun 2/05/2012 5:31 am by caricatu310873 | Last modified 8/05/2012 8:22 am by gavind | 4762 views | 5 replies |
caricatu310873Beta Tester
Greetings,
A couple of questions:
Is CSS Button Styler compatible with all browsers?
Does it produce CSS2 or CSS3 code?
Thank you in advance for your time.
yes, button styler is cross browser compatible.
it uses CSS2 code. In some instances it will use browser specific css code for rounded corners. Since rounded corners are not supported by all browsers, it will render as a square corner design on browsers that do not support rounded corners.
gavind
Quick question, if there's an upgrade say from FF, is an upgrade on this builder needed as well?
when you say;
"if there's an upgrade say from FF,..."
Do you mean a browser upgrade form FireFox?
if so, no, that will not need an upgrade for the Button styler, Browser upgrades address address bugs in the browser itself, it does not change the HTML Spec.
toms016390756
yea i didnt see any need for it
gavind
Thanks for clarifying this. I always thought you need both to be upgraded.
