need help with Dynamic Suite
Thread begun 2/02/2012 3:46 pm by identifyreport435363 | Last modified 2/14/2012 12:56 pm by Jason Byrnes | 5446 views | 10 replies |
I'm using Dreamweaver CS3 just got your Dynamic Suite. New to php and need help to just get going. Do i need to install php on my system, do i need to creat php page. I got your program so i could upload and download pdf I'm also dyslectic and need your help. Is it posable for me to talk to a person.
Chris Brady
before beginning with dynamic sweet, you will want to set up a local testing server. You will also need to set up your Dreamweaver site for dynamic development.
on the learning resources page, there are tutorials to walk through setting up the testing server for either Windows or Mac. There is also a tutorial for setting up your Dreamweaver Site.
the learning resources page can be found here:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
If you are planing to use DataAssist, you will need a database and to configure the database connection.
we offer a free database for eCommerce here:
ecommerce-database/
the learning resources page has details on configuring the database connection.
need help
2nd message on the eCommerce mySOL Database i'm not able to access Quick Links. how do i do that
to get to the eCommerce database page, go to the webassist.com home page, along the top menu, click the support link
on the support landing page, there is a link to the eCommerce database page along the right hand side.
This is a test
Beginner question 1
Jason,
After 12 days I finely have Apache, PHP and Mysql installed and working. I have some very basic questions.
I need to show my boss that your programs will fit his needs and i know they will with your help (customer service is very important to him)
My thought was to use one of your data bases and upload is to our test site so he can see it work. I think if I use the
“digital_ goods.sql” for the test.
I need to show before Thursday 2/16/2012 or he will want a refund (if this happens it falls on me 100% not you product).
Questions:
In your pdf "How to import a MySQL (.SQL) file to your database" under " What Do You Need to Start" I will be using "MySQL Workbench 5.2 CE" to do this when it asks for " An empty MySQL database already create" Now the question Where do i make this?
I'm sorry the such a basic question and i'm afraid there will be more
this thread on the stack overflow site should help:
create-a-new-database-with-mysql-workbench
need to creat a data base firest?
So i need to creat a data base firest? i thought “digital_ goods.sql” is a data base
the SQL file creates tables in your database.
where the it says:
"An empty MySQL database already created"
this means you need to create a Database, and have that selected as the active database before running the sql file, this tells MySQL what database to create the tables in.
thank you for your quick response
I'm so sorry for asking a stupid question. What time are you off and what time do you start. I'm in California i do thank you for your quick response.
