Product results grid - display more products
Thread began 2/02/2012 11:34 am by ericay278516 | Last modified 2/03/2012 11:52 am by Jason Byrnes | 3988 views | 12 replies |
ericay278516
I've searched through the forum and do not see any posts with this info. How can I change the number of products that display from the product results grid? Currently the grid is set to display 3 across and 3 down. I want to display 4 columns across and 5 rows down. Thank you.
this is not a supported modification to power store, increasing the number of products displayed across will break the css layout. the css is not created for 4 products across.
ericay278516
Thank you, Jason. If the css is currently fixed for 3 across, is it possible to add more rows down? We are flexible and could work with 5 or 6 rows (yielding 15 or 18 products per results page). Is this possible without breaking the css layout?
in the webassist/plugins/catalog/results_grid.php page, the following line sets the number of records to return:
$maxRows_WADAProducts = 9;
you can change that to :
$maxRows_WADAProducts = 15;
to return 15 instead of 9
ericay278516
Thank you, Jason. One more related question... can I adjust the display size of the thumbnails on the catalog page without compromising the image quality and without resizing all of the image files?
on the results grid page, the following code sets the width and height of the images:
$imgWidth = 200;
$imgHeight = 200;
you can change that to change the thumbnails size.
ericay278516
Hmmm, okay thumbnail size is changed. Thank you. I guess I'm also wanting to change the size of the actual grid... specifically the height of the rows. Where can that be edited?
that you would need to change in the css, using Fire Bug for firefox you should be able to pinpoint the css pretty easy, but this sort of modification is not supported.
ericay278516
Okay, Jason. Thank you for the assistance, thus far. You've been most helpful. Enjoy the rest of your Friday...
huh, i guess I've not had enough coffee. I thought it was Thursday....
thanks for saving me from coming in tomorrow....
