Files and directories cannot be created
Thread began 2/02/2012 7:05 am by admin140217 | Last modified 2/02/2012 1:19 pm by admin140217 | 868 views | 2 replies |
admin140217
I'm pretty sure I know why I'm getting this error however, I have installed the PowerStore Files in the root of the website, not a separate folder. Where would I assign the file/folder permissions for this error:
"Files and directories cannot be created. Verify the powerstore directory has write permissions on your server."
Should change the permissions on the powerstore folders, if so which one(s)?
Or
Is this a root directory issue?
you need to change the permissions on the directory that contains the power store files to allow write access.
admin140217
Solved for the moment, have another issue in a new post
