Validated entries and initial values
Thread begun 2/01/2012 2:13 pm by CJ | Last modified 2/02/2012 3:34 am by Ian S | 1448 views | 1 replies |
CJ
I have a form with some textfields. These fields have all initial values (with a sort of labelname, so the user knows what to fill in). When I bind the fields with the validated entries from the bindings panel all my initial values dissapear because the fields are loading the values of the valitade values (which are empty when I load the form for the first time).
Is it possible to have initial values in the form and when the page is loaded, then use the validated entries for the values? I hope I made myself clear.
Regards,
C.J. Ophorst
Ian S
Hi CJ,
Take a look at this post... it should help. It is possible to bind two values to the same form element, but it does require a little hand coding.
showthread.php?t=12008
Cheers
Ian
