Redirect on Insert Failure
Thread begun 2/01/2012 9:32 am by Mike Perry | Last modified 2/10/2012 9:45 am by Mike Perry | 4926 views | 9 replies |
Mike Perry
I looked but couldn't find a previous solution.
I am adding an Admin section that includes a Product Insert page created with DA 2.1. The product names must be unique, and are set up as a Unique field in the db. I want to trap the MySQL error that occurs if someone tries to add an already existing product name and display my own error page.
What code should I use to redirect to the error page, and where in the form processing code should I place it??
Thanks,
Mike
you will need to use server validation from either CSS Form Builder or Form Toolkit for this.
see this post for details:
showpost.php?p=20725&postcount=3
Mike Perry
Thanks, Jason. . .
Mike Perry
Hey Jason -- this validation checks for a value in EITHER field. I need to check for both being present in the same record.
Example:
brand: tester
product: tapeit
I need to find both items in the same record.
Thoughts?
create the recordset to check for both fields, it;s all in how you set the recordset filter up.
Mike Perry
Hi Jason -- I got this working, but i found I have another challenge to overcome before I can check it.
I need to include a brandID in the data for the Insert Record. The brandID is available in both the brands table and the products table (from current product records). I expect the best way to determine the proper brandID for the brand of the product being added is to query either the brands or the products table for the brandID where the brandName = the brandName from the form. However the code for the attached page inserts a (NULL) in the brandID column.
How can I extract the right brandID and add it to the Insert code?? I have excluded the recordset filtering code for now. . .
well, you should not be storing both the brand name and the brand ID in the products table, you should only store the brand ID. the brand name will be defined in the brand table.
you can get the brand name back when displaying the product info using a joined query.
see the following page for details on using join queries:
sql_join.asp
Mike Perry
Back to this one:
I'm having trouble figuring out how to set up the filtered RS for the validations.
I have three fields on the form: brandName (a dynamic select field), productName (a text field), and bName (a hidden dynamic select to capture the brandName for the record insert). Record Insert is working properly.
How do I create a useful recordset for the server validation validation? If I understand the flow, the RS needs to be create on the POST, and the validation needs to occur after the RS is created. Do I create (or copy) the recordset code inside the code for the validation, or is there a simpler way??
Current page code attached - throws an error even though I try to insert a brandName/productName combo that I know doesn't exist..
Thanks,
mp
the problem is code order.
the code for the validation is at lines 5 - 19
if ($_SERVER["REQUEST_METHOD"] == "POST")  {
$WAFV_Redirect = "";
$_SESSION['WAVT_productsinsert_231_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM($totalRows_validate . "",-1,0,"",",.",true,1);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"productsinsert_231");
this needs to be moved to line 87, so that validation occurs after the recordset and before the insert.
Mike Perry
  if (
$WAFV_Errors = "";
  if (
I always forget to check the code sequence -- thanks Jason. . .
