Log in twice problem
Thread begun 1/31/2012 11:38 am by bill3786 | Last modified 2/01/2012 7:55 am by Jason Byrnes | 2877 views | 5 replies |
bill3786
During testing it was possible to log in, add items to the cart and then log in again (no logout) as a different user. After the second log in the contents of the cart from the first log in were still displayed. Is it possible to clear the cart when a user does this?
you could add an clear cart behavior to the login page and set it to trigger on any form post.
on the server behaviors panel, click the plus button, select eCart -> Cart Display -> Clear Cart
bill3786
Tried this but doesn't clear the cart. Tried changing the trigger to Button:LogIn_submit pressed with same result.
double check to make sure that the clear cart behavior code is before the authenticate user code. If the authenticate user code comes first, it will redirect to the login success page before it can clear the cart.
bill3786
I have moved the clear cart behaviour before the code shown below and it works ok. Is this is the correct location for it, if it is, again many thanks.
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => $contweedmill,
"database" => $database_contweedmill,
"tableName" => "users",
"columns" => explode($WA_Auth_Separator,"UserEmail".$WA_Auth_Separator."UserPassword"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["Log_In_group_Email"]))?$_POST["Log_In_group_Email"]:"") ."".$WA_Auth_Separator."".((isset($_POST["Log_In_group_Password"]))?$_POST["Log_In_group_Password"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"UserID"),
"sessionNames" => explode($WA_Auth_Separator,"SecurityAssist_UserID"),
"successRedirect" => "login.php?loggedIn=1",
"failRedirect" => "login.php?failedLogin=1",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
yes, that is correct.
