( ! ) Parse error: syntax error, unexpected '}
Thread begun 1/31/2012 8:41 am by gary.brett434358 | Last modified 1/31/2012 12:49 pm by Jason Byrnes | 2415 views | 3 replies |
gary.brett434358
I have DA wizard to create the usual pages, after its done I have to edit the recordset as the results page will be displaying data from 2 tables. After doing this, it runs fine in the query window, I drag relevant fields to page, but when viewing I receive the error below:
( ! ) Parse error: syntax error, unexpected '}' in C:\wamp\www\tblcases_Results_Direct.php on line 33
This also happened on a set of previous pages which I simply deleted and started again, but wondered if this is something I could resolve, lots of my pages are manually edited with css so take a fair amount of time to keep redoing?
I have attached page if it helps?
Many thanks
change the code at lines 2 - 96:
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  if (
PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return
$theValue;
}if (!
function
  if (
PHP_VERSION < 6) {
  switch (
$theType) {
    case
"text":
      break;
    case
"long":
    case
"int":
      break;
    case
"double":
      break;
    case
"date":
      break;
    case
"defined":
      break;
  return
$theValue;
require_once('Connections/ghl_portal.php'); ?>
function
  if (
PHP_VERSION < 6) {
  switch (
$theType) {
    case
"text":
      break;
    case
"long":
    case
"int":
      break;
    case
"double":
      break;
    case
"date":
      break;
    case
"defined":
      break;
  return
$theValue;
function
  if (
PHP_VERSION < 6) {
  switch (
$theType) {
    case
"text":
      break;
    case
"long":
    case
"int":
      break;
    case
"double":
      break;
    case
"date":
      break;
    case
"defined":
      break;
  return
$theValue;
gary.brett434358
Again very much appreciated Jason, any reason why that would occur? Only thing I am doing different I think is editing the recordset that DA creates during wizard? Is it duplicating the code each time I change it? Same error happened last week when I set security on a page using SA?
Cheers
not sure why it is being duplicated, but removing the duplicate code will fix the problem.
