Reset password allows user to change email
Thread begun 1/30/2012 7:10 am by steelace396915 | Last modified 2/03/2012 10:55 am by Jason Byrnes | 3639 views | 8 replies |
steelace396915
Hi
I noticed a problem, at least for me, when testing the forgotpassword page built with SA wizard. I did not do any changes to it but tested it straight from the wizard. When the user recieves the email with the reset password link and is taken to that page its possible to change the email address to whatever along with the password. I did not reflect over this before and Im not sure this is the way it is supposed to be!? I would prefer that a user changing his password through that page has to enter his/hers registered email address and if it is not correct displaying a messege about the problem. Could I change this easily?
Thanks in advance,
Martin J.
steelace396915
Sorry I have asked this question before and got an answer from Jason! Just forgot about it. The original question and solution can be found here:
showthread.php?p=116752#post116752
I do wonder though if it would be possible to keep the email field on the reset password section and some way validate the address the user puts in against registered emailaddress in db and if not the same stop the form submit and display a messege to the user!?
Thanks in advance,
Martin J.
create a recordset that filters the email column on the entered email address.
then edit the server validations server behavior and add a like entry validation. For the Server Variable, select the email form element, for the compare to variable select the email address column from the recordset. this will cause validation to fail if the email cannot be found
steelace396915
Jason, I tried this but I don't get it to work all the way. Could you please take a look at the code for my forgotpassword page? It makes perfect sense the way you explained it though but I have probably made some little mistake I can't spot! I enclose the page in a zip file. Also enclosed 2 screen images on the settings in the recordset and the reset password Server Validation. Please take a look and see what I might have done wrong.
Thanks in advance!
/Martin J.
2 issues.
1) in the recordset filtering, you selected the Entered value filter type, you need to select form post filter type.
2) code order.
the recordset code is before the validation code, the recordset code needs to be moved so that is comes before the validation code.
steelace396915
Ok I see! I tried it Jason and the forgotpassword section works and sends email with reset link correctly to user. However on the reset page its now impossible to submit any email, registered or not registered. It seems like when Im moving the recordset above the server validation code the "SA Email Encrypted Password Return" behaviour is moved along with the recordset!? Could this have something to do with it does not work? Could you please take one more look at my page at this present stage!?
Thanks in advance!
/Martin J.
the only code that should be moved is:
$colname_rsEmail = "-1";
if (isset($_POST['StudentEmail'])) {
$colname_rsEmail = $_POST['StudentEmail'];
mysql_select_db($database_steelguitar_se, $steelguitar_se);
$query_rsEmail = sprintf("SELECT * FROM student WHERE StudentEmail = %s", GetSQLValueString($colname_rsEmail, "text"));
$rsEmail = mysql_query($query_rsEmail, $steelguitar_se) or die(mysql_error());
$row_rsEmail = mysql_fetch_assoc($rsEmail);
$totalRows_rsEmail = mysql_num_rows($rsEmail);
the forgot password code should not be moved.
steelace396915
Ok Jason, Ive moved that code and put it in a php block between the forgot password server validation code and reset password server validation code. The following error is reported in browser:
Fatal error: Call to undefined function GetSQLValueString() in /www/webvol20/4r/opk815z0jqke9td/steelguitar.se/public_html/student/forgotpassword.php on line 30
Also when I inserted the Like Entry value for the email field in the WA Server Validation (Reset Password) block I get a java script error warning like in the enclosed screen image.
I have checked everything many times according to your instructions but it does not work for me.
/Martin J.
