OrderID/customer order number
Thread begun 1/29/2012 1:56 pm by michaelrichards76429384 | Last modified 2/23/2012 2:05 pm by Jason Byrnes | 4254 views | 9 replies |
Hi.
I've set up eCart to use PayPal Payments Pro Hosted Solution (currently just sandbox).
As I offer a service, it is not an issue for me to simply check with PayPal that the payment has gone through before I fulfil the customers order, and the nature of the business is reasonably low volume.
My only remaining issue is that when I place a dummy order, the order number on the email receipt is incremental, for example if there is nothing in the database it starts at '1'.
I would like the order number to be the session id, but this does not get stored anywhere in my database.
Any help would be greatly appreciated.
Thanks.
in the orders table, add a new column named OrderReferanceNumber, set the data type to varchar(30)
on the confirm page, open the server behaviors panel and double click the eCart store Order summary behavior. select the OrderReferanceNumber column and click the lightning bolt next to value. Expand the eCart object data binding group and select the session id binding.
now double click the universal email server behavior. click the DW Edit icon to edit the email.
remove the Order ID session variable binding and replace it with the session id binding.
Thanks for the quick reply, Jason.
I will give that a go.
movygirl244169
Order Number
I'm having similar problems with my order number passing through the session. I made a few changes on the email form and the confirm page and now I get this response:
Unknown column '4ca7e2dd25277320605905170a8a27b1' in 'where clause'.
I just added some info like phone number & fax as wells as some verbiage describing the billing info for my client. When I followed the steps that is in the previous post for the order # I didn't test anything before that so I'm not sure if what I did with the changes or the order number is the problem.
I'm almost finished and just needed a few twitches & now I need some additional direction. I have upload the file for the check out file so that it can be looked at because it all worked fine until that point.
this error means that the session ID is being stored in a column that has the numeric data type.
in the store order summary and store order details behaviors, look for the column you have bound the session id to, and set the data type to text.
then in the database, you will need to change the data type for that column to varchar(20)
movygirl244169
OrderID
The where clause that is showing up with that weird number showed up on the email under the order number line.
the weird number is the session ID
like i said in my previous reply:
movygirl244169
OrderID
It won't let me change the orderID column into a varchar(20) and be auto increment.
movygirl244169
OrderID
Sorry I didn't see your update until after I had posted the previous info.
you should not be storing anything in the orderID column, do not bind the order id column to any value
since it is auto increment, you should let the data base set the value for that column and not try to force the session Id into it, that is whats causing the problem.
