Lost Links after inclusion
Thread begun 1/29/2012 1:05 am by clive.henderson222953 | Last modified 2/08/2012 1:42 pm by Jason Byrnes | 3636 views | 8 replies |
Hi
I have a page with a calendar with links that seems to work fine.
When I include it using Frame Builder the links don't work
Any help to solve this problem really appreciated.
The page with the calendar and link is here
calendar_ajax.php
A simple page with just the calendar included and nothing else is here but the links don't work
deleteme.php
Regards
Clive
on the deleteme.php page, in the source, I see the following code:
function MM_goTourl(ch_includes) { //v3.0
the case of the function name is wrong. it should be:
function MM_goToURL(ch_includes) { //v3.0
Thanks for the reply Jason
I've checked the included file and the all goto codes are in the correct case.
It seems the he incorrect case happens when the file is included.
I'm afraid I don't know how to change the code in the deleteme.php file to correct the case to re-test.
Any help appreciated again.
Clive
send a copy of both pages please.
Thanks againJason , here are the 2 pages plus framework and library files
includeproblem.zip
Clive
Hello Jason
Was the link I sent Ok for the pages?
Kind Regards
Clive
here is an updated copy of the webassist/framework/framework.php file to correct the problem.
Jason
Fantastic, Thanks very much!
All working well now.
Presumably, I need to use this file each time I include a such a file in future.
Anyway thanks again for solving the problem for me.
Kind Regards
Clive
yes, you will need to use this updated framework.php file in each site.
