Identify items in list view that are added to cart
Thread began 1/27/2012 12:55 pm by paulshoe379536 | Last modified 1/27/2012 1:26 pm by paulshoe379536 | 669 views | 2 replies |
paulshoe379536
I have a repeating table with thumbnails of each product. I would like to identify which of the items have already been added to the cart. What can I use to identify these items in my repeating table?
just before the repeat region, add the following code to create an array of all IDs of items in the cart:
$incartArray
= array();
while (!
$yourCart->EOF())      {
$incartArray[] = $yourCart->DisplayInfo("ID")
$yourCart->MoveNext();
$yourCart->MoveFirst();
where yourCart is the name of your eCart object.
then in the repeat region, add this code to check if the current record id is in the array that was created
<?php if(is_array($incartArray) && in_array($row_rsName['ProductID'], $incartArray)) echo("item is in the cart"); ?>
where rsName is the name of your recordset and ProductID is the name of the ID column.
paulshoe379536
Works perfectly! Thanks for the help Jason!
