Data Assist not writing upload value
I am having an issue with DA and the upload file SB, the file filed added to the form after creation IS uploading the image however it is not writing the image name value to the database.
Extension background:
Pages were created with 2.0.8, after removing cache file and uninstalling/re-installing extension then recreating DA pages with the same results, I located the 2.0.9 release of DA and received the same results, upgraded to 2.1.0 which I am running currently.
I also had the same redirect issues many of the other users have mentioned and attempted to resolve with the advice in the forums, I updated the library files in all locations to the latest release in my downloads section with no improvement. The issue was resolved by commenting out the rel2abs function. The values of the upload field are blank either way, with or without the rel2abs function.
I should also mention, I have attempted to cure the situation by rearranging the order of functions on the page to see if the upload was executing too early with no positive results.
Regards,
Gary
