JavaScript error when applying Server Validation to Captcha
Thread begun 1/26/2012 8:31 am by bbifl346249 | Last modified 2/14/2012 11:53 am by Andrew Read | 5483 views | 9 replies |
bbifl346249
I'm receiving the message;
While executing onUnload in WAFV_LikeEntry_S.htm, the following JavaScript error(s) occured.
At line 14 of file
".......\WAFV_LikeEntry_S.js": wa.user_interface.-onUnload is not a function
The message is displayed after pressing 'OK' having specified the the form component (Security_Code_1).
Page attached.
I've cleared the cache and tried re-installing the extensions (in this order); WASocial, WACookies, WAeCart, Surveyor, SiteSculptor, UE, ForTK, SecurityAssist, WADataAssist.
what version of Security Assist? if it is security assist 2, you should not be installing cookies toolkit.
also, if it is security assist 2, it should be the last extensions installed, not Data Assist.
try uninstalling form toolkit, cookies toolkit, and security assist.
deleting the cache file, then reinstalling form toolkit, data assist, then security assist.
bbifl346249
Yep, that resolved it.
"try uninstalling form toolkit, cookies toolkit, and security assist. (And Data Assist)
deleting the cache file, then reinstalling form toolkit, data assist, then security assist."
Thanks :D
Andrew Read
Please post known issues to a sticky and downloads!
OK - Once again I am going to harp on the Known Issues posting for these extensions...
This is clearly a known issue for these extensions and I can't find a sticky or known issue posting in the downloads section for any of these extensions.
So instead I have to waste time deleting and re-installing these extensions once again.
Please PLEASE PLEASE come up with some sort of standardized way of posting these known issues so that your customers can avoid these issues.
Thank you.
I posed a sticky thread on the topic here:
showthread.php?t=24005
Andrew Read
That's great, how about where I downloaded all of these files.. and even better would be an indicator on the downloads page of which extensions that I own that are made redundant, and by which extension.
Such as a big red X over the icon for Security Assist 1 when I own Security Assist 2 (a very obvious example but one none the less...)
Also, in the downloads area a suggested installation order would be great, and this should include any current patches that need to be applied....:)
I will forward your suggestions.
Andrew Read
Also, in that list where does Design Extender stand - will it cause any issues with any of the extensions when installed afterwards?
Thanks.
I would still install security assist last, install Design Extender, then install security assist.
Andrew Read
AAAACK!!!! I am now going to do a full uninstall and reinstall of all of these because of that. :(
