Column 'image' cannot be null
Thread begun 1/25/2012 11:51 am by ericbass213433382 | Last modified 1/25/2012 2:29 pm by ericbass213433382 | 8463 views | 4 replies |
ericbass213433382
How do you get this File Upload to work correctly.
plz give instructions with the intention of someone else understanding plz
Thankyou Eric
from your description of the error message, it is not the file upload that the problem, it is the Insert record behavior that is the problem.
send a copy of your page so i can examine the code to see what you have in place.
ericbass213433382
Thanx in advance
Thankyou Jason
so, you have a Dreamweaver insert behavior that does not insert anything to the images column, followed by the upload server behavior, then the Data Assist insert server behavior to insert the image.
this wont work.
the error is happening on the DW insert behavior, since nothing is being inserted to the image column, it is causing the error.
even if the error where not occurring, it still would not work, because you would have one record for the product info, then another record for the image.
get rid of the DW Insert record behavior, and keep the data assist one.
set the data assist insert record behavior to use the form bindings for the other columns.
ericbass213433382
That fixed it! I appreciate the help!
