Userupdate email verification
Thread begun 1/25/2012 12:16 am by steelace396915 | Last modified 1/30/2012 2:00 pm by steelace396915 | 1234 views | 2 replies |
steelace396915
On my userupdate page its possible for registered users to update all their registered information as well as their registered email address. If someone update their email through the userupdate page I would like them to verify that new email address, in an email messege they recieve, before they will be able to login to the site again. How do I accomplish this?
Thanks in advance!
/Martin J.
Ian S
You users table will need a verified field that is set to either 0 or 1.
On update you will need to store the old email address (possibly in session variable or hidden field).
When the user changes their email address you will need to create an email (possibly using UE) and Update behaviour to update and then custom code the trigger to make it compare the old email address to the new. The email would contain a link to a page that lookups the email address and then sets the verified field to 1.
Also, add a second update behaviour which sets the verified field to 0, again custom code the trigger to make it compare the old email address to the new.
You will probably also need to change your login script to make sure that the value of the verified field is equal to 1.
Hope this helps.
Cheers
Ian
steelace396915
Thanks Ian, I did not notice your reply until now. I will try doing something like that and I'll holler again if I hit the wall! ;=)
Cheers,
Martin J.
