Unable to open script: WA_Configuration.js
Thread begun 1/24/2012 10:38 am by Justin@AdventDesign | Last modified 1/16/2014 4:25 pm by Jason Byrnes | 4331 views | 7 replies |
Justin@AdventDesign
This one has eaten up a lot of time for me today. Working on adding file upload behavior to a data assist form. On the insert page, when I try to open the insert record behavior to make the proper change to the behavior, I got the following error message:
"The following JavaScript error(s) occurred: Unable to open script file "Macintosh HD:Applications:Adobe Dreamweaver CS4:Configuration:Shared:WebAssist:DataAssist:Library:WA_Configuration.js" (error 2)."
Tried disabling and re-enabling extensions. No go.
Then uninstalled, downloaded fresh copies, reinstalled and it worked for the insert page.
Then, I attempted to do the same to the update page and... get the same error message above.
Delete the Dreamweaver Cache file from the users configuration folder:
Justin@AdventDesign
Still no good
Tried quiting, dumping the MacFileCache and restarting DW several times. Same error.
Dumped the MacFileCache again. Removed the DataAssist and Universal Email extensions and reinstalled. Same error.
PatriceWebAssist
I am getting this now too. I found that I didn't have the latest databridge, so deleted old, deleted new cart, reinstalled with cart last.
this is pretty much the same issue as you reported earlier today.
it should be fixed when the updates that will be released today are out, I'll let you know when they are live.
PatriceWebAssist
OK…thanks… Thought maybe my updating to 1.1.5 messed it up.
New Dot releases have been uploaded to the download section for:
eCart 6.0.1
Design Extender 1.1.7
Data Bridge 1.1.6
Free Tools 1.0.8
these versions should correct the problems you are having.
uninstall the previous versions from the extension manager, then install the new ones
