Universal Email and Dynamic Dropdowns - No Target List content?
Thread begun 1/23/2012 8:07 am by steve287725 | Last modified 1/25/2012 11:38 am by Jason Byrnes | 4223 views | 7 replies |
steve287725
Hello there
I have used Dynamic Dropdowns to successfully populate the (3rd) Target list on a user form, from the Parent and Child lists, and use Universal Email to send the results.
The issue is that UE does not appear to include the contents of the Target List - just blank in the resulting message.
Would there be any known reason for this?
Also I notice that Dynamic Dropdowns has been discontinued today - any reason? New stuff in the pipeline?
Steve
send a copy of your page and the webassist/email folder so i can examine the code.
steve287725
Attached
Jason
Thanks for the reply - folder attached
Steve
steve287725
And the page . . .
Attached - sorry forgot to attach it to the email folder zip
Thank you
few things:
1) for a multiple select list, you need to include [] at the end of the name to create an array of the selections. change:
<select name="Target" size="10" multiple class="optionsbox" id="Target">
</select>
<select name="Target[]" size="10" multiple class="optionsbox" id="Target">
</select>
2) Just because the items are added to the target list does not mean they will be inclded when the form is submitted, they need to be selected. to automaticly select all items in the target list when the form is submited, add the following javascript code to the head of ypou page:
function selectAllOptions(selStr)
var selObj = document.getElementById(selStr);
for (var i=0; i<selObj.options.length; i++) {
selObj.options[i].selected = true;
</script>
and change the submit button:
<input id="submit" name="submit" type="submit"/>
<input id="submit" name="submit" type="submit" onclick="selectAllOptions('Target');" />
3) the multiple select list will send an array, it needs to converted to a comma separated list. add the following code at line 1 to accomplish this:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
        if(
is_array($_POST[$key])) $_POST[$key] = implode(", "$_POST[$key]);
steve287725
Thank you
Jason
You are a gent and a scholar.
I have to say that WebAssist provide a level of support which is to say the least unusual nowadays, and goes above and beyond.
Many thanks not only for the support but for the advice.
steve287725
Small issue
Jason
All the code you sent me yesterday works fine - the only thing is that the Target list sends (emails) the Child record UID field value instead of the 'label' field value as displayed - am I missing something obvious?
Steve
well, that's is the way select lists work, you have the value of the selct list set to use the dd_child_UID column. when submitted, the form sends the value, not the label.
change the javascript for selecting al elements to this:
selObj.options[i].value = selObj.options[i].text;
</script>
this will cause it to change the value of each item to the label.
