problem adding images to Long Description
Thread begun 1/23/2012 7:49 am by Marleen | Last modified 1/23/2012 11:04 am by Jason Byrnes | 1264 views | 1 replies |
Marleen
I get an internal server error 500 when trying to load images from the server into the Long Description. The error log says:
PHP Warning: require_once() [<a href='plugins/function.require-once'>function.require-once</a>]: open_basedir restriction in effect. File(../../../../Connections/PowerStoreConnection.php) is not within the allowed path(s): (/var/www/vhosts/*****.**/httpdocs:/tmp) in /var/www/vhosts/*****.**/httpdocs/webassist/kfm/configuration.php on line 1
...and then some.
This suddenly started, it never used to happen, and as far as I'm aware I haven't changed anything.
Hope you can help with this. Thanks!
