Form Validation working incorrectly for file size
Thread begun 1/23/2012 3:31 am by Rune Brynestad | Last modified 1/23/2012 9:36 am by Jason Byrnes | 2436 views | 5 replies |
Rune Brynestad
I am trying to validate 2 fields.
The first is a text field that I want to be required.
The validation works correctly.
The second is a file field that I want to validate for type of file and also for file size
If I try to upload a wrong file type the validation works.
But if I try to upload a file that is too large, the error message for file size does not show up.
I'm attaching my working file.
Regards
Rune
you are validating for less than 10 MB, what size file are you uploading?
I am testing your page on my system with a 18mb file and the validation is working fine.
to help troubleshoot, change:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"gavesoknaderInsert_110");
        die("<pre>".var_dump($_FILES)."</pre><br /><br/>".$WAFV_Errors);
and post back the results of a large upload.
Rune Brynestad
I'm validating a 26 MB file.
The output when I modify the code are:
array(0) { }
,1
When you test on your system with a 18mb file, do you see the error message "Maximum file size is 10 MB" ? I don't.
Regards
Rune
yes, i do see the "Maximum file size is 10 MB" error message when testing on my system
the results you posted mean that you did not enter anything for the required text box.
make sure to fill in the text box and upload a file when testing.
Rune Brynestad
Sorry Jason, but I have a value in the required text box. Still the same output.
