Can I use WebAssist to convert urls to hyperlinks?
Thread begun 1/22/2012 12:49 pm by ovknox388992 | Last modified 2/14/2012 6:46 am by Jason Byrnes | 6343 views | 10 replies |
ovknox388992
I am using DW CS5, MySQ, PHP, Form Builder 2, DataAssist, etc. I have created a registration form with Security Assist to gather basic information about businesses that subscribe to my website. This form has entries for email, password, website url, etc. It requires the following format for the website url: (www.mywebsite.com). The url information downloads into MySQL just fine. However, these records are stored simply as a urls, not a hyperlinks.
I need to create a recordset that incorporates these urls and displays them as hyperlinks in a table on my website. The table is part of a Master/Detail page set. I want to create two links in each row in the Master table. One link would redirect the visitor to the Detail page (I know how to do that) but I want the other link to redirect the visitor to the business website. Obviously, the record set displays the urls on the master page, but not as hyperlinks. Is there an easy and practical method to convert these urls into hyperlinks? If possible, would this be done with Dreamweaver, PHP, or MySql, or a WebAssit Extension? Is there an automated method that will write code for me? If you have a solution or suggestion it will be greatly appreciated. Much Thanks!
Ian S
You do not need any third party extensions to create hyperlinks in Dreamweaver.
You simply make the A HREF dynamic, telling it to include the database value as the link.
e.g.
<a href="<?php echo ($row_myrecordset['url']); ?>" target="_blank"><?php echo ($row_myrecordset['url']); ?></a>
Regarding the query you will need to create a SELECT query with a JOIN. This can be done with the standard Dreamweaver Recordset but you will need to know a little bit about mySQL syntax as it needs to be typed manually. The query will look something like this, but obviously depends on your table and field names.
SELECT fields FROM table1 INNER JOIN table2 ON table1.id = table2.foreignkey
Cheers
Ian
ovknox388992
Problem converting urls into dynamic hyperlinks
Thanks IAN for your assistance. I think I am on the right track, but I am new at this and would appreciate a little more assistance please. I am obviously still doing something wrong. The data is pulling up just fine, but the "url" field in the jobs table is displayed only as a url, but not as a link. Currently {rs_job.url} appears beneath the table as a link, but it disappears when I open my browser. Any advice will be much appreciated.
I have created two tables with the following fields:
1. construction
Business_ID
BusinessName
Position
Salary
State
2. jobs
Job_ID
Business_ID
url
My Recordset is: (rs_job)
SELECT construction.Business_ID, construction.BusinessName, construction.Position, construction.State, construction.Salary, jobs.url
FROM construction INNER JOIN jobs ON construction.Business_ID=jobs.Business_ID
My Code is:
<table width="100%" border="1">
<tr class="Leadership_Table_Header">
<td>business</td>
<td>position</td>
<td>salary</td>
<td>state</td>
<td>website</td>
</tr>
<?php do { ?>
<tr>
<td><?php echo $row_rs_job['BusinessName']; ?></td>
<td><?php echo $row_rs_job['Position']; ?></td>
<td><?php echo $row_rs_job['Salary']; ?></td>
<td><?php echo $row_rs_job['State']; ?></td>
<td><?php echo $row_rs_job['url']; ?></td>
</tr>
<?php } while ($row_rs_job = mysql_fetch_assoc($rs_job)); ?>
</table>
<a href="<?php echo ($row_rs_job['url']); ?>" target="_Blank"><?php echo ($row_rs_job['url']); ?></a>
Ian S
Hi!
How is your link being stored?
Are you storing it as www.website.com or www.website.com
You will need to include the http:// either in your database, or as part of the link....
<a href="http://<?php echo ($row_rs_job['url']); ?>" target="_Blank"><?php echo ($row_rs_job['url']); ?></a>
Otherwise your browser will not know what to do with the URL.
Cheers
Ian
ovknox388992
Still Struggling with Converting urls to Hyperlinks
Thanks LAN for your patience. I am storing the urls in the database as follows: www.website.com. Does it need to be ? I have tried it with and without the .... but with no success. I am at a total loss. I must be doing something fundamentally wrong. There is probably a very simple solution. Any other suggestions?? Thanks again for your patience.
can you send a link to a page that shows the problem, this will help us determine what the problem may be.
ovknox388992
Hyperlink Error
This link will illustrate what I am trying to accomplish. I hope it is what you need. Thanks!
Index.php
like Ian had posted before, the fix is to change:
<td><a href="http://<?php echo $row_rs_job['url']; ?>"><?php echo $row_rs_job['url']; ?></a></td>
it does not look like you have tried to implement this on the page you have linked to. What I was asking for was a page that you have tried to implement the code on where it is not working.
ovknox388992
Hyperlinks
Thanks.....I will see if I can make it work....
ovknox388992
Thanks Ian & Jason
Thanks a million! That did the trick. "Change" was the key word here. I was adding code when I should have been changing it. When you know what you are doing it is "awfully simple" and when you don't know, it is "simply awfully." Thanks for being patient with slow learners.
