Blank Results, Insert, Update pages
Thread begun 1/21/2012 10:10 am by contact318852 | Last modified 1/23/2012 6:45 am by Jason Byrnes | 1917 views | 2 replies |
contact318852
Ah I found the correction the local database connection was referenced in two parts of the code on line 96
$WADAapplications = mysql_query($query_limit_WADAapplications, $local) or die(mysql_error());
Changing that made things work.
I am attempting to modify a set of admin pages in data assist, the current pages are working fine which I had created before upgrading to version 2.08. But the new pages done in 2.08 and those I created after upgrading to 2.09 have the same error behaviour on pages I have recreated.
The pages work perfectly on my local wamp server php 5.30, mysql 5.05 but when I upload them to my remote server php 4 ,mysql 5.05 and do a search the results page opens as a blank white page (with no source code) - so showing errors is impossible.
I have changed the connections include on all pages where it is required.
Im hoping someone can nudge me in the right direction to find where my error might be.
cheers
Ian S
A blank white page could indicate that you have white space between your PHP tags at the top of the page.
Check to make sure you have no spaces between your tags for starters.
Cheers
Ian
a blank page indicates that a php error has occurred, but error reporting is turned off.
you will need to turn error reporting on to see what the error is, this will give a direction for troubleshooting.
to error reporting on, add the following code at line 1 of your page:
error_reporting
(E_ALL);
