Server Behavior panel cannot determine whether "Command" ...
Thread begun 1/20/2012 5:13 pm by ccooper309155 | Last modified 8/26/2013 3:14 pm by Jason Byrnes | 4509 views | 8 replies |
ccooper309155
Suddenly getting this goofball message in DW5.5 on Win7:
"The Server Behavior panel cannot determine whether "Command" or "Recordset (Query)" is applied to your page. Please select Edit Server Behaviors and change one of the two behaviors to ensure that each is uniquely identifiable."
Crazy thing is, it only happens on my workstation.
DW5.5 on my laptop opens the same .asp pages without this crazy message popping up.
What's more, it seems to have only started happening after adding an Add to Cart button to the page.
Anybody know what the issue is?
first, Delete the Dreamweaver Cache file from the users configuration folder:
if you continue to get this error, send a copy of one of the pages that is causing the problem.
ccooper309155
Hi Jason
That was the first thing I tried. Will send a copy of the page tomorrow morning. Thanks.
bill181745
Same problem
Jason, I have the same issue, did you resolve the problem?
I did delete the Cache file, same problem, using CS5
Bill
bill181745
test page for above problem
Jason, I put this test page together because I wanted to isolate the problem, still have the same problem with the recordset and command.
please compress the page to a zip archive and send the zip file instead of pasting the code.
bill181745
Jason, here is the attached file in rar format
your eCart object and the connection are both using the same name:
umab
you must use unique names for the connection and the eCart object.
