problem with redirect after insert record
Thread began 1/20/2012 1:59 pm by JBWebWorks | Last modified 1/20/2012 2:38 pm by JBWebWorks | 1787 views | 2 replies |
JBWebWorks
have Data Assist 2.08 and just upgraded to DW CS5.5
using DA to insert single record and the problem i'm having is with the redirect (the insert is working properly)
The problem is not redirecting after the insert.
In IE it shows not found and in Firefox, i get this error message
The requested URL /var/www/vhosts/casaolepensacolamexicanrestaurant.com/httpdocs/thankyounewsletter.php was not found on this server.
Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny13 with Suhosin-Patch mod_ssl/2.2.9 OpenSSL/0.9.8g mod_perl/2.0.4 Perl/v5.10.0 Server at www.casaolepensacolamexicanrestaurant.com Port 80
thankyounewsletter.php is the page for the redirect and it is on the server?
just building the site now, but you can see this here
index_new.php
thanks for your help,
-Jim Balthrop
here is an updated copy of the WA_DataAssist/library.php file that should correct the issue
library.zip
JBWebWorks
Thanks, Jason.
Yes, that fixed it.
I appreciate your quick response.
-Jim
JBWebWorks
This post has been deleted.
