adding 'modules'
Thread begun 1/20/2012 6:59 am by JamieEff | Last modified 1/23/2012 8:43 am by JamieEff | 1319 views | 2 replies |
JamieEff
adding 'modules'
Hey there
Just wondering about creating a site with ecommerce.
Basically, am just wondering if the process is to create the site layout and use PowerCMS and then you integarte ecart into that framework, or would you do everything using ecart?
And if you wanted to add the gallery option, is that easily integrated into however one does the above?
Sorry if its a bit vague!
Jamie
as with everything, there is more than one way to skin a cat.
power CMS _can_ be used to add content to your store, but it is not necessary, you could use static content instead of dynamic CMS content.
there is not a one size fits all answer to your question, but the basic outline you mention would work as a way to create a eCommerce website, and yes a gallery can be added to the site using power gallery.
JamieEff
thanks Jason
