Dynamic List/Menu values from table
Thread begun 1/19/2012 8:01 am by gary.brett434358 | Last modified 1/25/2012 4:32 am by gary.brett434358 | 6512 views | 14 replies |
gary.brett434358
Good afternoon,
Using DA wizard I have created insert, update, detail & results pages. On the insert/update pages I should have dynamic List/Menu fields that are populated from another database table.
I can easily enough manually add these fields but is it possible to change the DA created fields to allow the options from another table, which ever one is selected gets written to the table? To test I created a new recordset from TblContactType and built dynamic list from that, now just need to get this into the DA created form & db.
Quick Example:
TblContactType has option1, option2, option3, option4
On the insert/update page the field called ContactType is like this
<div class="rowElem"><label>ContactType:</label><div class="formRight"><input type="text" name="ContactType" id="ContactType" value="" size="32" /></div><div class="fix"></div></div>
I would like this to become a list/menu holding options from TblContactType, then when a user selects Option 4 lets say this is stored in DB table?
Thanks for any advice offered.
do this when running the data assist wizard.
in the data assist wizard, select the ContactType column, and set the display as option to Menu, click the edit icon to set the menu to be dynamic set the table to use the TblContactType. set the value to the ID column and the label to the name column.
gary.brett434358
Again that's great Jason, brilliant support. Have tried this on a test site and all worked great, is there any way I can run this on an existing DA recordset? I have spent best part of 2 days customising the pages created by DA wizard with my own CSS! If I can do this without having to overwrite existing pages it would be fantastic?
Kind regards
it's a manual process to do it on an existing page.
create a recordset to return the data from the TblContactType table
in design, select the ContactType form element and delete it
insert a select list, make sure to set the name to "ContactType"
in the property inspector, click the dynamic button.
set it tot use the TblContactType recordset, use the ID for the value and the name column for the label.
on the update page, click the lightning bolt next to select value equal to and select the ContactType column from the main recordset (not the TblContactType recordset)
gary.brett434358
Will try the manual way in the morning Jason, its late here in UK now. Am I right in thinking the above steps are done in designer view of insert/update pages?
yes, that is correct.
gary.brett434358
Hmmm, I must be stupid! Have done the manual process, all looks o except the value of the list box doesnt get written to the tblContacts - ContactType column.
I may need to nite the bullet and do it the wizard way then redo all CSS.
Code attached if you have time, if not no problem I appreciate the time you have spent so far.
regards
the update record behavior does not have the contact type column bound to anything.
in the server behaviors panel, double click the Update Record server behavior.
select the ContactType column and click the lightning bolt next to value, bind it to the ContactType form element.
gary.brett434358
Can you see if that is that now bound? Still doesnt update the ContactType Column in tblContacts?
I am struggling to get my head round this, can you tell?
gary.brett434358
Originally Said By: gary.brett434358
Sorry attached now!
