Error after installing DataAssist 2.09
Thread begun 1/18/2012 2:53 pm by lwoolsey359935 | Last modified 1/19/2012 7:59 am by Jason Byrnes | 1723 views | 3 replies |
lwoolsey359935
I just update DataAssist to the 2.09 version (previously using 2.08 with the patch). I keep receiving this error (see screen capture). I've tried uninstalling the extension and re-installing it, but still receive the same message.
Please advise.
Thank You,
Lee Woosley
Delete the Dreamweaver Cache file from the users configuration folder:
lwoolsey359935
Still getting the error.
jason,
I following the instructions you provided, and deleted the Cache file. The error still repeated. So, per the documents instructions, I removed the extension and re-installed it.
I still get the same error, but I did note that it only seems to occur when I try to invoke the "Update Single Record" command, I tried the "Insert Single Record" command and did not have any error.
Any other ideas?
