DataAssist 2.0.9
Thread begun 1/18/2012 1:44 pm by Surdej Web Solutions | Last modified 1/19/2012 7:58 am by Jason Byrnes | 3152 views | 4 replies |
DataAssist 2.0.9
Hey guys! Not my week for building with Data assist.
I have the redirect error happening but with DataAssist 2.0.9 installed. Actually got the email about the release and installed it today. Now on any update or insert page, I get redirect to a url with /home/user/public_html/ added in front of my default directory. Anyone know what could be the problem?
I have actually tired the fix with the library.php file but no luck. I did uninstalled and then did a re-install with hopes that it had something to do with the previous version but it didn't help.
Thanks for your help,
Jeff
DataAssist 2.0.9
This post has been deleted.
DataAssist 2.0.9
The error is corrected on the Update, Insert and Delete pages if I change the following line on my insert record or update record server behavior:
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
to
if (function_exists("")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
However, If I update the insert/update behavior, I have to go back and change it again.
Try this newer version of the library file, if that does not work, I will start an incident to look into the issue with you.
DataAssist 2.0.9
Hi Jason,
I tried that but had no luck. Thank you your help.
Jeff
