Removing Data from MySql Data base
Thread begun 1/17/2012 6:06 am by maftouh | Last modified 1/18/2012 1:21 pm by Jason Byrnes | 2963 views | 3 replies |
maftouh
Hi.
I've created a smoll data base to record contact information and feedback from a website visitors. As well as i created it, data are now recorded and printed in a files that retrieve data from my MySql db.
What i would like to do now is to set a bouton that can allow administrator to remode a record without going to the PHPMyAdmin. (This administrator can be a besktop assistant, so, he may don't know more about webmastring)
i guesse that the Sql syntax can look like this :
DELETE FROM `contact`.`client` WHERE `client`.`fullname` = \'My Name\' AND `client`.`email` = \'name@domaine.com\' AND `client`.`phone` = 3333333 AND `client`.`subject` = \'tQuerry\' AND `client`.`message` = \'test data base contact message \' LIMIT 1
And i want to create a bouton to remove a record. For exemple, the bouton will be called : "remove".
SO, here is my question : how can i set the link in this bouton and connect it to this Sql syntax in order to remove the record ?
if you have an advice on the Sql syntax that can be much better, please do help me.
THank so much
Use DataAssist to create a set of database management pages. The pages created by the DataAssist wizard will allow you top delete records, insert new or update old ones, it will also create a search and results page.
maftouh
Thank you Jason.
unfortunatly, i'm not able to purchase for an item for this time being.
i don't have neither visa card, nor Mastercard or any online shopping card.
that why i allways request for help.
any way, thank you for all your help.
if you have any other suggestion, please give it to me.
Regard.
see the dreamweaver documentation for creating a master detail page set:
help.html?content=WScbb6b82af5544594822510a94ae8d65-78b7.html
from there, look at the documentation for creating an insert and update page.
I would recommend looking at some some PHP / MySQL Books for further details and step by step walkthroughs.
the David Power Foundation PHP book is a good starting place and is geared towards php / mysql development in dreamweaver specifically.
