Shipping charge not reflecting quantity purchased of same item
Thread begun 1/16/2012 9:53 am by jam396972 | Last modified 1/16/2012 12:48 pm by jam396972 | 4232 views | 9 replies |
jam396972
Hi Jason,
First of all, wishing you a Happy New Year!
I have set up the site with UPS shipping and a handling charge for each item. Everything seems to be working fine with a single purchase of an item, however, the UPS charge is not reflecting any increased item sales (more than 2 sold of the same item). It just keeps the same single item shipping charge no matter how much the quantity is increased. The handling charge does increase accordingly to the larger quantity sales. I am sure I tried this out before and the UPS amount was working fine. I don't know what I did or how to change the code to have the UPS pick up the total quantity of items when duplicates are ordered of the same item.
Many thanks!
Please upload a copy of the page where the UPS shipping server behavior is applied and I can take a look at what is wrong.
Most likely you are referring to the field value for "Weight" instead of "TotalWeight" when passing the value to UPS, but if I look at the page I can refer to line numbers and the specific code you need to update.
jam396972
UPS Shipping Charge & Quantities Sold
Hi Ray,
I did look into the coding for "Weight" vs. "TotalWeight", but when I adjusted things it didn't resolve the issue. I am attaching the cart.php and confirm.php pages. Thank you so much for your help and attention on this.
jam396972
Total Weight
Hi Ray,
I just noticed that it is the "TotalWeight" that is not calculating the Weight * Quantity correctly. Again, I know this was working before and I don't know what I could have done to change it. I'll be looking into this, but if you can direct me to the appropriate location to adjust this, it would be greatly appreciated! :)
jam396972
Total Weight
Sorry about this. I found where to correct the TotalWeight increment and it is working fine. However, I am still having the same problem with the UPS shipping amount. I am attaching the updated files.
What is the issue you are having now? I'm a bit confused when you say:
"working fine. However, I am still having the same problem with the UPS shipping amount"
I'm not sure how it can be working fine but you still have the same issue. Please describe in detail what the current issue is and I'll try to figure out the cause.
jam396972
I was refering to the TotalWeight column amount, that it was working properly. The UPS shipping amount is picking up only a single item sale, not the "TotalWeight" increment. I am very sorry about the confusion.
jam396972
Ray,
On the confirm.php, I adjusted the 'Weight' to 'TotalWeight' on line 188. That does seem to increase the shipping amount according to the total weight ordered. Since we have to ship each item individually (and I did note this going through the checkout wizard when I set the shipping up), how can I set up the shipping charge by quantity instead of by weight. In other words, for example, right now for a single item:Table 1 the shipping is $17.48. On a quantity of two it is $28.80, not $34.96 (double the $17.48 charge). I can't adjust it with a shipping rule. Can this even be done? Thanks again.
You could try replacing the code:
$Shipping_PackageArray[$Shipping_PackageIndex]["eCart_Quantity"] = (($Shipping_Packaging == 1)?$guitartables->DisplayInfo("Quantity"):1);
$Shipping_PackageArray[$Shipping_PackageIndex]["IsPackage"] = "true";
$Shipping_PackageArray[$Shipping_PackageIndex]["Quantity"] = "1";
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "".strtoupper($guitartables->WeightUnits)."LBS" ."";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".WA_eCart_FormatNumber($guitartables->DisplayInfo('Weight'), true, 1) ."";
with:
$Shipping_PackageArray[$Shipping_PackageIndex]["Quantity"] = (($Shipping_Packaging == 1)?$guitartables->DisplayInfo("Quantity"):1);
jam396972
Works perfectly! Thank you so much!
