Email Form
Thread begun 1/16/2012 1:21 am by salaroche | Last modified 1/16/2012 11:02 pm by salaroche | 1543 views | 2 replies |
salaroche
Email Form
Jason:
Could you kindly tell me why the attached email form doesn't do anything when I click the "Submit" button? Everything else seems to be working fine, but when I click the "Submit" button the form just flickers a bit and stays put; it doesn't even show the progress bar.
Thank you for your attention
It is failing server validation. It looks like you created the form with a field called "Email_Address" but you may have deleted that field and left the server validation on the page. You'll need to remove validation on fields when you remove fields from your form.
In this case, delete line 13 of your script. You can tell when it is failing validation because "?invalid=true" is added to the url.
salaroche
Ray:
It works.
Thank you
